There they opened it without a clean room. They scratched the top plate and left fingerprints on it.
The heads looked like they had been torn from the ramp.
So far I have ignored the top surface condition. I swap the donor heads to see if it would ever start.
Unfortunately, it did not move. Heads clicking and spin off so I guess H5 fell.
I tried to edit the head map in RAM. However, LDR upload is needed for this.
When I try to load module 11 I get an error message.
Permanent ovl (11) data uploading Device Error Detected: "Unknown error. Error code: BFA0"
5c is loaded correctly.
When I transferred the heads back to the donor, the donor doesn't start anymore either
What is problem?
