WDC WD20EARX
sepid
WDC WD20EARX
Postby sepid » 04.11.18, 15:15
hi guys
i have a hdd wd WDC WD20EARX-00PASB0
this hdd no id and after 10sec spin stop
i did "upload Dir in to hdd Ram " then message is :
Module (0001) read error Module ID 01 reading error Data request error - Device Error Detected: "SERVO ERROR CODE BASE SvirADChang"
i did "upload Dir in to hdd Ram "+ load from file and I've uploaded madule 11 from hdd Similar
Servo ovl(5C) data uploading............ : Ok
Permanent ovl (11) data uploading....... : Ok
hdd id :
Model : WDC WD20EARX-00PASB0
Serial : WDC-ROM SN# XYZ----
Firmware : 51.0AB51
Capacity : MB (1)
But the spindle does not rotate,spin stop
i renter utility
Techno mode key
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "SCT INVALID FUNCTION CODE"
Modules directory address............... : 377 469
ROM Modules:
ROM version............................. : 27.74R
ROM F/W version......................... : 00270074
Overlay F/W version..................... : 27.75R
Servo F/W version....................... : 0C.07
Heads map............................... : 0,1,2,5,6,7
Service area:
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirADChang
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : ABA 377 469(1) reading error; unexpected error: UBA 377 469 is out of translation
thanks
Re: WDC WD20EARX
Postby Amarbir[CDR-Labs] » 04.11.18, 17:58
Looks Like a Head Issue ,Swap Heads And Try Again
sepid
Re: WDC WD20EARX
Postby sepid » 05.11.18, 10:39
It is not possible for me to change the head for me
Is there another solution?
Maxim_TS
Re: WDC WD20EARX
Postby Maxim_TS » 07.11.18, 14:39
sepid, try to edit head map in RAM: http://blog.acelab.eu.com/ram-head- ... -case.html
