I've a WD 1TB green, WD10EADX DCM=HHNNNT2MHB, with heads failure.
I also have these 2 similar WD 1TB green disks:
WD10EARS, DCM=HGNYHT2MAB
WD10EAVS, DCM=HANNHT2CAB
Can I use one as heads donor?
Thanks in advance
heads replacement
- cuumaytinh
Re: heads replacement
See mode factory in table untility If mode is same may be can used.
