I have a WD 2 TB model WD 20 NMVW.
I had shifted the region.
Now can not go back. Whenever I a doing allow SA region, still it shows region shifted.
Can someone help how to have the region address.
ROM version............................. : 21.3RH
ROM generation.......................... : 21.3RH
Link table version...................... : N0.41.
Consolidated ROM version................ : 0021003R
ROM Modules:
Modules directory address............... : 318 128
SA regions address...................... : shifted
SA defects assigned..................... : 1
Heads number in use..................... : 8
Heads map............................... : 0,1,2,3,4,5,6,7
ROM Firmware version.................... : 0021003R
SA region address can not be shifted back
Re: SA region address can not be shifted back
Can't you write back the original ROM?
Are you running the shift in Ram or in Rom?
For me you are working in Ram, and you must shift the regions in Rom
Imnew, go to Work with ROM->Allow SA access and restart HDD menu.
Imnew wrote:Source of the post I have a WD 2 TB model WD 20 NMVW.
ROM Modules:
The Basic Strategy I Use For Backup Is As Following ,I Enter The Utility In Kernel Mode And Read Rom And Rom Modules Then i Quit Utility Enter Inside Utility again And Read Modules In ABA Mode of Different Heads And Make New Profile ,Like This i Have Two Profiles Of One Drive With ROM And Rom Modules in One And ABA Accessed Modules In Second One .Like This i Have Entire SA With Me And Can Undo Anything .In Your Case You Should Undo This Process By Writing Back Initial Saved Rom Or Using What Maxim Tells You [ though There Are Two Methods To Undo This In Tool ] . BTW Acelab TS Guys The Earlier Version Had " Shifted " Written in Red and It Was So Easy To See this Can You Ask Developers To Change Colour If Shifted To Red In The Very Next Update You Fellows Make .
Amarbir[CDR-Labs] wrote:Source of the post BTW Acelab TS Guys The Earlier Version Had " Shifted " Written in Red and It Was So Easy To See this Can You Ask Developers To Change Colour If Shifted
It will be marked red in next 6.4 version
Maxim,
i would say that good features of one version should be retained in all further versions like this colour thing cheers mate
