HOW DO GENERATE ROM FROM ROM MODULES IN TRAILXLS
datasolution
Postby datasolution » 04.09.15, 19:27
DEAR SIR,
AS WE ALL KNOW WE CAN GENERATE ROM IN ROYAL FAMILY FROM MODULES.BUT I CANT FIND ENOUGH MODULES FOR IT IN THIS NEW FAMILY.AFTER CHANGE SA REGIOON WE ACCESS SA AREA AND FIND MOD BY SA SEARCH.BUT UNABLE TO FIND MOD 107 LIKE IN OLDER VERSION OF HDD IN ROYAL .IF WE ARE TRYING TO CREATE ROM FROM THIS RECOVERED MOD IT GIVES ROM NOT ALL ROM MODULES .SO WE CAN USE ONLY ROM BUT NO ROM MODULES.LIKE HEAD ADAPTIVES 30 ,4F,2B ETC IN CASE OF ORIGINAL PCB LOST OR ROM CURRUPT.PLS HELP ME IF ANYONE KNOW.
THANKS.
Re: HOW DO GENERATE ROM FROM ROM MODULES IN TRAILXLS
Postby AJ2008 » 07.09.15, 09:53
Manually create ROM from #109 and write it in Kernel, then write ROM modules from similar resource (same FW revision is not important for this step). You may need to adjust head map if donor has different map.
datasolution
Postby datasolution » 08.09.15, 18:50
thanks for reply sir.
my problem is as given below
Techno mode key
SA SPT.................................. : 1706
ROM reading............................. : Module ID 0B reading error Data request error - Device Error Detected: "CA FLUSH ALL GOT CANCELED"
Service area:
SA dir reading (ID)..................... : CA FLUSH ALL GOT CANCELED
SA dir reading (ABA/CHS)................ : No S/A regions info avalable
what else can i do ? I have seen this for first time
