How to select Sata PCB compatible with the one USB PCB 2060-800041-003 rEV P1
Posted: 21.12.18, 16:40
by tonoarimany2012
Hi Everyone
I have this usb hard drive WD40NMZW-11GX6S1
To find the right Sata PCB what i have look at is
Thank you
Re: How to select Sata PCB compatible with the one USB PCB 2060-800041-003 rEV P1
Posted: 21.12.18, 17:47
by unspoken
Posted: 02.09.22, 16:37
by fastec
you can do it more easily and more precise
the heads/controller driver on the board is B20, B22 and B23 (not yet seen any B21, but it may exists)
so just check the smaller squared chip on the spindle connector side of the board and check its version
Obviously it must match between the USB and the SATA board
So far we have seen B20 on PebbleB and B22/B23 on SpyGlass
Posted: 05.02.24, 10:50
by jojo2012
Tried 2 SATA PCBs: 2060-80002-002 and both have the same problem: status register all ON and no spinup. With the USB PCB (SATA conversion) there is SED enabled.
Posted: 14.02.24, 10:31
by jojo2012
Solved with USB PCB SATA conversion and help from TS
