WD10SMZW-11Y0TS0 with encrypted ROM...
Posted: 06.06.18, 19:37
by 300ddr
I don't believe I've seen this before. Drive is SED encrypted. I moved ROM to SATA PCB and shorted TV9/10, still can't read ROM (same if I blocked head contacts) -- "SED Locked." I removed and manually read ROM in a ROM reader... it looks almost completely encrypted.
Is there no way to access firmware on this kind of drive with encrypted ROM?
Copy of ROM here: https://slack-files.com/T041AF3B4-FB2QX290T-43c038afb9
Thanks,
Brian
Re: WD10SMZW-11Y0TS0 with encrypted ROM...
Posted: 07.06.18, 11:07
by Maxim_TS
300ddr, it's a new, currently unsupported Palmer family.
We will appreciate if somebody knows how to deal with them :)
Regarding ACE Team, our Developers are working on it now.
Posted: 03.09.18, 17:26
by Doomer
Maxim_TS wrote:300ddr, it's a new, currently unsupported Palmer family.
I do, you can outsource
Posted: 04.09.18, 03:14
by 300ddr
Hi Doomer,
Are you saying you can access the FW on these drives? If so, then at least there is hope for the future :).
Posted: 04.09.18, 15:10
by Doomer
300ddr wrote:Source of the post Hi Doomer,
Yes, on these and on Charger too (2TB 7mm)
Posted: 28.10.18, 14:10
by Amarbir[CDR-Labs]
300ddr wrote:Source of the post I don't believe I've seen this before. Drive is SED encrypted. I moved ROM to SATA PCB and shorted TV9/10, still can't read ROM (same if I blocked head contacts) -- "SED Locked." I removed and manually read ROM in a ROM reader... it looks almost completely encrypted.
Thanks,
Brian
I Am Able You See Al Usual Signatures In This ROM Sir ,No Issues With That .
