I have the above mentioned Hard Disk. its a USB Drive.
Can someone tell me which family is this.
Also any compatible SATA PCB ?
What family is WD10SDZW-11UMGS0
Re: What family is WD10SDZW-11UMGS0
Why not search the PCB number and see what you find?
If I had to guess, I'd say it's probably Spyglass family, but it could also be a new one. Either way you can probably work with it using a newer family like PebbleB to at least get to read module C5 and see what family it is.
The PCB is 2060-800069-001 REVP1.
What is the compatible SATA PCB
I would guess it's either 800066 or possibly 800052 but I've never had a case here to test that out. I'm just guessing based on the MCU.
