Soldering of SATA Connector
Posted: 20.04.17, 08:08
by lka124
Can someone help me to determine the capacitors, wich are to solder and the contacts for the SATA-Connector (E71, E72, E73, E75 are right?)?
Re: Soldering of SATA Connector
Posted: 20.04.17, 14:06
by LarrySabo
Posted: 20.04.17, 14:25
by lka124
Thanks so much, I was not sure.
Posted: 25.04.17, 05:30
ika124 ,
Were are you from ,Can you tell me this might be i can conduct a small class online on my Facebook for you to understand this concept properly ,But i suggest you swap to a data board as you will have the ability to switch on and off the drive specially if you do not have the USB power connecter acelab has released now
Posted: 25.04.17, 05:41
by lka124
Hi Amarbir,
i'm from Germany, near Berlin. I have the USB power connector. I've also solder the capacitors, but I can not find a wire that fits in these holes
Posted: 25.04.17, 13:43
Please Connect to me on my facebook and send me a message ,I will then take a special class for you and explain you this my German friend
