wd5000lmvw-11ckrs0 terminal connection
Posted: 03.11.16, 07:47
by GuideRecovery
has anyone tested what is terminal connection scheme for this drive ?
PCB is: 2060-771859
thanks in advance.
Re: wd5000lmvw-11ckrs0 terminal connection
Posted: 04.11.16, 09:27
by GuideRecovery
anyone has any clue ?
Posted: 04.11.16, 12:58
by lcoughey
It works fine with the WD terminal adapter.
Posted: 11.11.16, 12:58
by GuideRecovery
my bad, dont have WD terminal adapter, still using Toshiba.
Its time to get those new terminals.
thanks for pointing out.
Posted: 12.11.16, 13:19
by GuideRecovery
today i got comaptible SATA pcb for this drive, ROM chip on SATA PCB is different in shape and in size (512KB) whereas the ROM of patient is 256KB.
my question is is it safe to write the patient rom after pading zeros at the end of it and make size 512KB ?? has anyone tested it ?
USB PCB IS: 2060-771859-000
SATA PCB : 2060-771852-004
or i should simply move ROM chip to donor SATA PCB.
thanks
Posted: 12.11.16, 14:09
by GuideRecovery
Jrrrrrrrrrrr.. samsung terminal adapter work just fine.
BAM...
