WD usb HDD wd10jmvw kernel mode
Posted: 17.04.16, 20:34
by mscerl
Hi everyone
i connected the WD usb drive through SATA pins(by soldering the wires on the PCB)
when i start the utility, it connects in kernel mode!
what's the problem ?
How can i run it in normal mode?
Re: WD usb HDD wd10jmvw kernel mode
Posted: 18.04.16, 17:42
by Amarbir[CDR-Labs]
mscerl wrote:Source of the post Hi everyone
Before You Do Anything Could You Please Read the ROM Of This In USB Mode "Using Toshiba Com Port Adapter " And Program That Read Rom Into a SATA PCB And Try Running It Once .If Its Still In Kernel Mode It could Be A Firmware/Head Issue And We Will Tackle It Later ,First Try This
Posted: 20.04.16, 18:13
by DataMedics
Kernel mode means the SA hasn't fully loaded into the PCB RAM. It could be the result of bad heads, damaged firmware modules, or a lot of other things.
Posted: 22.04.16, 10:57
by Maxim_TS
mscerl, how long the wires are? If they are longer than 1 inch, shorten them, and restart the drive.
