What family is the WD5000LPCX-22VHAT0?
Posted: 04.03.16, 20:58
by osity
1. Is it not possible to auto detect the family when using the PC3K over USB?
2. What family is the WD5000LPCX-22VHAT0?
3. Can the resources be backup up through USB connection?
Re: What family is the WD5000LPCX-22VHAT0?
Posted: 05.03.16, 15:35
by pclab
To know the family, check module C5.
You can read modules by USB if the drive is healthy or use terminal cable connected to the PCB.
Posted: 05.03.16, 16:43
by osity
Yes I'm dealing with healthy drives. What utility are you suggesting I used to read the modules? I do not intend to open the enclosure as it is completely rubberized. (So no terminal access)
Posted: 05.03.16, 21:26
by pclab
You just plug it to USB and choose WD USB on PC3K utility.
It will work as sata WD.
Posted: 06.03.16, 02:02
by osity
To open the utility you need to choose a family....
Posted: 06.03.16, 12:04
by pclab
Choose any family.
That you can read the C5 module and see the family.
Posted: 06.03.16, 17:29
by osity
oh... ok thanks for the tip Pclab!
Posted: 07.03.16, 00:03
by pclab
Did it worked?
Posted: 08.03.16, 00:57
by osity
I have not tried it yet, but when i do I will post back. It may be a few days.
Posted: 10.03.16, 16:50
by Maxim_TS
osity, most possibly it is HUBLT2, it is not presented in PC-3000 for now. You can work with it using Hubble LT family.
Posted: 10.03.16, 17:19
by Amarbir[CDR-Labs]
Maxim_TS wrote:Source of the post osity, most possibly it is HUBLT2, it is not presented in PC-3000 for now. You can work with it using Hubble LT family.
Maxim,
Many New Families Are To Be Added In WDC I Have Come Across Many
Posted: 15.03.16, 12:08
by Maxim_TS
Amarbir[CDR-Labs], I agree, WD added a lot of new families recently, and ACE developers are working on it already.
