Power-off and power-on cycle on USB
Posted: 25.01.16, 16:42
by recovery
I search tools to do a power-off cycle for USB devices like WD/Samsung or other USB devices. I imagine a tool to connect USB devices to SATA port of PC3000, then make a copy with DataExtractor. Do you have an idea about such tools?
Re: Power-off and power-on cycle on USB
Posted: 25.01.16, 17:32
by DataMedics
recovery wrote:Source of the post Hello,
Why not just convert the PCB to a compatible SATA one? It's just a quick ROM transfer. And no, no such tools exist. The method of communication via USB and SATA are very different, so a simple converter like that still won't help anything as you'd still be limited by what you can do over USB.
Posted: 25.01.16, 17:41
by recovery
For an USB 3 PCB, I thought we cannot find a compatible SATA PCB. I will search more :wink:
Posted: 25.01.16, 18:51
by lcoughey
The only tool that I know that can handle power cycling USB devices is a DeepSpar Disk Imager with the USB add-on.
Posted: 25.01.16, 21:00
by DataMedics
recovery wrote:Source of the post For an USB 3 PCB, I thought we cannot find a compatible SATA PCB. I will search more :wink:
Just post the board number 2060-771XXXX and I can tell you which one to use.
Posted: 25.01.16, 21:01
by DataMedics
lcoughey wrote:Source of the post The only tool that I know that can handle power cycling USB devices is a DeepSpar Disk Imager with the USB add-on.
Even that really never works, I've yet to see it actually see it power cycle a USB drive. I asked DeepSpar about it, and they said it can't. I don't know.
Posted: 26.01.16, 09:29
by recovery
The PCB is 771949.
I can buy a 771959 or a 771931 I think.
Posted: 26.01.16, 18:29
by DataMedics
771959 is the board you need.
Posted: 29.01.16, 14:09
by Maxim_TS
Hello Everybody,
There is a list of known USB - SATA compatible boards here at forum, please look: viewtopic.php?f=155&t=8376&p=29087#p29087
Posted: 08.02.16, 09:01
by Filipp_TS
USB reading/writing mode have a lot of restrictions and as result a lot of options are not available.
But if you need just to switch on|off power supply via USB..
I think that better to save a money: :wink:
