Maxim wrote:>Does PC3000 UDMA supports WD USB3 drive?
PC3000 UDMA does not support USB3 yet.
But you can solder sata connector
to PCB and work with this drive as usual.
>is there any manual about how to swap the WD USB3 PCBA wtih SATA PCBA?
You can swap compatible SATA PCB with USB3 PCB.
It is necessary to transfer the native firmware with a USB drive on a SATA card.
To do this you must read ROM from USB PCB and write it to a donor board.
Maxim,
thank you for your reply
The reason I did not just change the connector is because the problem I faced now is I cannot detect the drives at all, so I am thinking of swaping the USB3 PCB to SATA PCB.
From your reply, you mentioned that "transfer the native firmware with a USB drive on a SATA card...", and yes this is what i looking for, but unfornately, UDMA cannot detected my good USB3 PCB as it only has Venus (USB2) families. Is my software the latest? Do we have other way to read the ROM from USB3 PCB?
