SED v2 Backup
Posted: 23.07.24, 22:19
by LostDataSA
I have charger with 810003 after converting it to SATA I can access the data but the PCB is unstable, how can I backup the SED to a file and use SATA PCB 800065 and continue the recovery since there is an option to load SED from file or folder
Re: SED v2 Backup
Posted: 29.08.24, 21:12
by JGRivers
With the SMR drive families, most drives have hardware encryption and don't use the decryption key found using the "Decrypt" function. In these cases, you have to move the CPU and ROM from the patient drive to the SATA board in question (you could also use an external programmer to copy the ROM to the donor board). To my knowledge, there isn't yet a way to get the CPU to spit out its hardware SED key. Mind you, the CPU migration is a very difficult and delicate process, so take care to practice on donor boards beforehand. It may be helpful to have a dedicated SATA board with the CPU removed and re-balled with low-temperature solder for these situations. Be delicate with the application of heat to minimize risk of damaging the CPU (and even then, it could still fail) and protect the plastics in the SATA connector and the headstack connector.
