WD 1TB WD10JMVW Getting Busy when Detecting
Posted: 04.01.23, 10:05
by gameboybin
I have a WD Elements WD 1TB WD10JMVW. When it plugged through USB the drive is spinning fine however the lights on the usb drive flashing and the drive never got recognized
With the PCB 2060-771961-001 REV B
I swapped the PCB with the donor 2060-771960-000 REV A. Swapped the BIOS also
I have looked through the PCB Compatibility before swapping the PCB over. So in theory it should be working
Starting up the drive the DRD and DSC lights up like normal
However when i get into PC3000 Auto Detection The BSY lights came up and never turns off.
What should i do???
Thanks For helping
Re: WD 1TB WD10JMVW Getting Busy when Detecting
Posted: 04.01.23, 14:10
by SGdata
Did you check relo-list?
Posted: 05.01.23, 05:14
by msurgeon
Short TV9 and TV10. SA is bypassed. This will put drive in ready state and should allow for auto detection.
Posted: 05.01.23, 05:33
by gameboybin
SGdata wrote:Did you check relo-list?
Did You mean checking relo-list on Doner PCB before swapping???
Posted: 05.01.23, 07:56
by SGdata
No. I mean run in kernel and check relo-list. Read the article on ACE blog.
Posted: 05.01.23, 14:25
by gameboybin
msurgeon wrote:Source of the post Short TV9 and TV10. SA is bypassed. This will put drive in ready state and should allow for auto detection.
Same thing. Did not work. Here is the video of the problem
https://www.veed.io/view/65322c35-a88e-48e8-b558-31cda6749de0?panel=share
Posted: 06.01.23, 01:50
by msurgeon
Just to be sure: you kept points shorted until drive came ready? This should have put the drive into kernel mode allowing for detection. Alternative: isolate heads; enter kernel mode; block SA. Then remove isolation and re-start.
Posted: 06.01.23, 08:53
by gameboybin
msurgeon wrote:Source of the post Just to be sure: you kept points shorted until drive came ready? This should have put the drive into kernel mode allowing for detection. Alternative: isolate heads; enter kernel mode; block SA. Then remove isolation and re-start.
Yep, The Alternative did it THanks msurgeon
Blog URL that i used
https://blog.acelab.eu.com/pc-3000-hdd-how-to-solve-slow-responding-problem.html
Thanks Everyone!!!
