[SOLVED] WD40NMZW-11GXS1 SED SpyGlass (simple) heads map
Posted: 02.09.22, 16:54
by fastec
premise: the ROM from the USB board written in the unlocked SATA board returns again a SED locked drive.
Unlock the ROM with new utility 7.1.10 looks not supported for SpyGlass simple mean those with board 800041
So I did this process which for one part allowed something, but now I'm stuck
I did
- read the USB original board ROM
- written it in the unlocked SATA board
- blocked module 30
- uploaded compatible dir and loader from donor FW
- restarted utility in normal mode
- saved all the modules
but here you don't have an ID and don't have drive capacity neither if you soft reset,
at this point I have a personal memory bug :-) sorry
now how do we create the heads map? I ask it because as said above uploading compatible dir and loader from donor FW and restarting in normal mode won't give any capacity nor ID neither if soft reset
I'm sure I forget something though I dont' edit HDD ID because I'm not sure about possible actions and eventual consequences with SpyGlass
Thank you for any hint about
Re: WD40NMZW-11GXS1 SpyGlass (simple) heads map
Posted: 05.09.22, 08:45
by fastec
Now with original modules saved
I have restarted the drive and uploaded original DIR and OVLs and module 02
I have ID but I don't have capacity
any suggestion about making the heads map is welcome
thank you
Re: [SOLVED] WD40NMZW-11GXS1 SED SpyGlass (simple) heads map
Posted: 07.09.22, 11:34
by fastec
Ok
solved
reason for this entire topic is that we are not so confident about editing HDD ID in the SpyGlass
thoug since heads were tested and fine both reading and writing. we edited HDD ID
removed the usual SED tick, and the rest is as usual
interesting to be noticed that SED v2 is now supported and decrypted correctly (not yet aware of that)
