WD40NMZW-11GXS1 (4TB WD MY PASSPORT) - damaged USB board (solved)
Posted: 22.03.22, 09:11
by radovanhlavacek
Hello, I had case 4TB WD MY PASSPORT - WD40NMZW-11GXS1. This drive had damaged PCB. This was Spyglass drive with active SED. Original USB board 2060-800041-003 was not usable. I choosed simple way to get data, use SATA compatible board and ROM chip swap. In my case, it was SATA board 2060-800022-002. Data were successful backuped.
This topic I created as inspiration for others...
Re: WD40NMZW-11GXS1 (4TB WD MY PASSPORT) - damaged USB board (solved)
Posted: 22.03.22, 09:26
by RevocoTT
Hi radovanhlavacek,
Thanks for contributing :thumbup: , keep up the good work.
Posted: 22.03.22, 09:52
by radovanhlavacek
Thank you very much.
