WD10JMVW-11AJGS4 USB HDD Recovery
Posted: 14.03.21, 18:42
by d1d
Hi @all,
i have a WD USB 2,5" HDD here.
The HDD was by an other Datarecovery Lab.
They open the HDD. So i have also a look into the HDD but the Heads looks good and there are no scrates on the surface.
So i have bought a comp. SATA PCB and change the PCB also i have solderd the ROM from the USB PC to the SATA PCB.
I have make a backup from the ROM Files but i can´t get access on the Data.
What i´v made wrong?
I knwo i must make a Recovery training but i think i have done what Luke Grudnoff the old Owner of Day1 Data told me.
So anyone an idea?
Thanks a lot and best wishes
Luigi
Re: WD10JMVW-11AJGS4 USB HDD Recovery
Posted: 14.03.21, 22:20
by SGdata
Does the drive get full ID? Did you check modules?
Posted: 15.03.21, 15:52
by d1d
Hi SGdata,
so thats what i get....
ROM Modules:
ROM version............................. : 16.94H
ROM F/W version......................... : 00160094
Overlay F/W version..................... : 16.94H
Servo F/W version....................... : NA.41
Read ROM
Into file............................... : <HDD Profile>\Data\ROM\ROM_16-94H_16-94H_NA-41.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 20B............................ : Ok
Module : 30............................. : Module ID 30 reading error Data request error Device Error Detected: "FM ERR FILE ID"
Module : 47............................. : Ok
Module : 0D............................. : Ok
Module : 4F............................. : Ok
Module 0x90 read error.................. : Module ID 90 reading error Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
Module sector read error................ : No SA copy avalabled
Module sector read (Head 0)............. : Physical read error C/H/S: -1/0/1 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
Module sector read (Head 1)............. : Physical read error C/H/S: -1/1/1 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
But it dosen´t get the ID.
Luigi
Posted: 15.03.21, 16:24
by Maxim_TS
d1d, Block SA access in ROM, restart the drive, and load donor loader to the patient RAM.
http://files.hddguru.com/download/PC-30 ... 68T1JN.rar
Then go to Normal mode and check if Service Area modules are readable.
Posted: 15.03.21, 18:25
by d1d
Hi Maxim_TS,
hope you are fine!
Thanks for your replay, but it dosen´t work, same Problem....
Modules directory address............... : 16 180
SA regions address...................... : shifted
SA Translator loading................... : Module ID 30 reading error Data request error Device Error Detected: "FM ERR FILE ID"
ROM Modules:
Overlay F/W version..................... : 16.95H
HDD SA unblocking....................... : Ok
Firmware restart........................ : Ok
Best wishes
Luigi
Posted: 16.03.21, 16:07
by Maxim_TS
Luigi, save ROM and ROM modules to the backup folder. Are all ROM modules good in log after the saving?
Posted: 16.03.21, 16:48
by d1d
So i can save the Rom and all Moduls whitout the Modul 30 Translator....
The Moduls and the Rom locks good in Hex...
As Example Modul 0D in Attachments.
Best wishes Luigi
Posted: 18.03.21, 13:09
by Maxim_TS
Looks like ROM module 30 is damaged. Try to write it from the same ROM FW version donor backup.
Posted: 21.04.21, 14:23
by d1d
Hi Maxim_TS,
it dosen´t works....
So maybe Heads weak?
Best wishes
Luigi
Posted: 26.04.21, 19:04
by Maxim_TS
d1d wrote:Source of the post So maybe Heads weak?
hard to say, need to check remotely. Please contact us at https://ts.acelab.eu.com/
