Some info about USB to SATA conversion of WD PCB:
2060-810012-000 ?
(WD40NMZM)
PCB 2060-810012-000
Re: PCB 2060-810012-000
2-E71
3-E72
5-E73
6-E76
Expand view
3-E72
5-E73
6-E76
- crashpcberlin
Mekanik wrote:Some info about USB to SATA conversion of WD PCB:
2060-810012-000 ?
(WD40NMZM)
I have just solved the slow responding problem on a same drive with a 2060-810012-000 USB-C PCB using a 2060-800022-002 SATA-PCB via ROM-soldering.
It worked fine. So i think you can add them to the list, Maxim.
Greets
crashpcberlin, added, thank you very much!
