wd10tmvw-11zsms1
Posted: 10.12.19, 11:27
by FDRC
when i have swap the rom from wd usb 2060-771737-000 to sata board 2060-771692-005 rev 5 not getting power
when i have put back the other rom its working
so what is the problem i have check other pcb of same number 771692
Re: wd10tmvw-11zsms1
Posted: 11.12.19, 11:03
by l.pascal
It may be that the 2 ROM on different sizes
Posted: 11.12.19, 15:03
by FDRC
can u send the pics for pcb were are 2 rom
by FDRC
so that i can swap 2 rom
Posted: 11.12.19, 20:09
by lcoughey
Maybe you should consider contacting a data recovery pro in your area.
Posted: 12.12.19, 05:48
by digitalsupport
lcoughey wrote:Source of the post Maybe you should consider contacting a data recovery pro in your area.
+1
Posted: 12.12.19, 10:11
by FDRC
thanks guys i will try to usb soldering its good
Posted: 12.12.19, 12:29
by digitalsupport
If you have ROM removed, make a backup using external programmer and write it back to SATA pcb via boot ROM.
I prefer to read and write ROM via boot instead of soldering.
Posted: 12.12.19, 19:03
by FDRC
yes i have try its showing rom space is low to write
