PCB 2060-810012-000
Mekanik
PCB 2060-810012-000
Postby Mekanik » 04.03.20, 18:58
Some info about USB to SATA conversion of WD PCB:
2060-810012-000 ?
(WD40NMZM)
Maxim_TS
Re: PCB 2060-810012-000
Postby Maxim_TS » 10.03.20, 15:23
2-E71
3-E72
5-E73
6-E76
Expand view
Collapse view
crashpcberlin
Postby crashpcberlin » 18.05.20, 20:01
Mekanik wrote:Some info about USB to SATA conversion of WD PCB:
2060-810012-000 ?
(WD40NMZM)
I have just solved the slow responding problem on a same drive with a 2060-810012-000 USB-C PCB using a 2060-800022-002 SATA-PCB via ROM-soldering.
It worked fine. So i think you can add them to the list, Maxim. :)
Greets
Maxim_TS
Postby Maxim_TS » 26.06.20, 19:51
crashpcberlin, added, thank you very much!
Return to “WD USB”
