WD10TMVW-11ZSMS4 head donor help
SGdata
Postby SGdata » 18.05.17, 09:30
I'm trying to find a heads donor for this drive among SATA drives. Just got exact the same one with USB PCB, but if those heads fail is there any alternative?
Drive has 6 heads so it's a little taller than normal drives.
WD10TMVW-11ZSMS4
DCM:HHMT2BBB
Any tips?
Maxim_TS
Re: WD10TMVW-11ZSMS4 head donor help
Postby Maxim_TS » 18.05.17, 10:26
Hello SGdata, Lookf for the close DCM and same family, head map, date and country donor drive.
SGdata
Postby SGdata » 18.05.17, 10:49
Does these infos include heads number? My question was is there a SATA version of this drive. With 6 heads.
datanet
Postby datanet » 18.05.17, 12:43
Dear All;
I am new for PC-3000 UDMA
when I star using the utility I got such error message
HDD MODEL: WD blue WD10JPVX-60JC3T0
Techno mode key
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules directory address............... : 183 696
ROM Modules:
ROM version............................. : 16.14G
ROM F/W version......................... : 00160014
Overlay F/W version..................... : 16.14G
Servo F/W version....................... : NA.18
Service area:
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActPdFail
SA dir reading (ABA/CHS)................ : Techno key error; unexpected error: Operation aborted
Could you please help me to understand and solve the problem
datanet
Postby datanet » 18.05.17, 12:58
SA SPT Detect........................... : FAIL
P-List reading.......................... : Module ID 33 reading error Data request error Device Error Detected: "Unknown error code: 3746"
G-List reading.......................... : Module ID 34 reading error Data request error Device Error Detected: "Unknown error code: 3746"
T-List reading.......................... : Module ID 36 reading error Data request error Device Error Detected: "Unknown error code: 3746"
Relo-List reading....................... : Module ID 32 reading error Data request error Device Error Detected: "Unknown error code: 3746"
Return to “WD USB”
