I was imaging this drive and it gave me an error. After power Off/ON I get this error:
Techno mode key
SA SPT.................................. : 1480
Read ROM................................ : Module ID 0B reading error; unexpected error: Data request error; unexpected error: SAT command error: Device Error Detected: "CA FLUSH ALL GOT CANCELED"
Service area:
Module ID 109 reading error; unexpected error: Data request error; unexpected error: SAT command error: Device Error Detected: "CA FLUSH ALL GOT CANCELED"
What is this?
WDC WD5000LMVW-11VEDS3
Re: WDC WD5000LMVW-11VEDS3
Maybe SA address cant be known?
Does modules table from this look OK?
Rewrite 0B from backup, or from one in database of same FW. If not available, write any module and manually set to address it should be.
