What family is the WD5000LPCX-22VHAT0?
osity
Postby osity » 04.03.16, 20:58
1. Is it not possible to auto detect the family when using the PC3K over USB?
2. What family is the WD5000LPCX-22VHAT0?
3. Can the resources be backup up through USB connection?
pclab
Re: What family is the WD5000LPCX-22VHAT0?
Postby pclab » 05.03.16, 15:35
To know the family, check module C5.
You can read modules by USB if the drive is healthy or use terminal cable connected to the PCB.
osity
Postby osity » 05.03.16, 16:43
Yes I'm dealing with healthy drives. What utility are you suggesting I used to read the modules? I do not intend to open the enclosure as it is completely rubberized. (So no terminal access)
pclab
Postby pclab » 05.03.16, 21:26
You just plug it to USB and choose WD USB on PC3K utility.
It will work as sata WD.
osity
Postby osity » 06.03.16, 02:02
To open the utility you need to choose a family....
pclab
Postby pclab » 06.03.16, 12:04
Choose any family.
That you can read the C5 module and see the family.
osity
Postby osity » 06.03.16, 17:29
oh... ok thanks for the tip Pclab!
pclab
Postby pclab » 07.03.16, 00:03
Did it worked?
osity
Postby osity » 08.03.16, 00:57
I have not tried it yet, but when i do I will post back. It may be a few days.
Maxim_TS
Postby Maxim_TS » 10.03.16, 16:50
osity, most possibly it is HUBLT2, it is not presented in PC-3000 for now. You can work with it using Hubble LT family.
Postby Amarbir[CDR-Labs] » 10.03.16, 17:19
Maxim_TS wrote:Source of the post osity, most possibly it is HUBLT2, it is not presented in PC-3000 for now. You can work with it using Hubble LT family.
Maxim,
Many New Families Are To Be Added In WDC I Have Come Across Many
Maxim_TS
Postby Maxim_TS » 15.03.16, 12:08
Amarbir[CDR-Labs], I agree, WD added a lot of new families recently, and ACE developers are working on it already.
Return to “WD USB”
