Anyone heard of VIVETRONIC HARD DRVES? *pic
osity
Postby osity » 26.10.18, 20:16
Picture attached.
It has a Seagate 100781943 PCB on it, but I get no terminal output.
After clicking, Seagate utility identifies itself as: OOS500G128M.
Clicks, then spins down.
With the rosewood utility, I can read ROM but that's about it.
Re: Anyone heard of VIVETRONIC HARD DRVES? *pic
Postby digitalsupport » 28.10.18, 09:13
Have seen a few here of these TP53126200 500 GB. Actually 1TB Rosewood probably failed Seagate QC (did not know they had any)
Sold to vivetronic with lower capacity. Did not have any trouble unlocking it with Rosewood utility here.
osity
Postby osity » 29.10.18, 18:58
Thanks!
Should I be looking for a 500GB donor or a 1TB donor?
Postby digitalsupport » 29.10.18, 20:39
Most likely its a 1TB, but who knows if they would sell a failed 2 TB as 500 GB
You better check heads.
Postby Amarbir[CDR-Labs] » 31.10.18, 17:34
osity wrote:Source of the post Thanks!
Well,
Open it up and check ,It can even be a 2 platter 4 head 2tb converted to 500gb :D
osity
Postby osity » 07.11.18, 18:27
Amarbir,
I opened it up. 1 Platter, both sides of it look good. Heads are dirty on both sides.
Removing the heads is extremely difficult on this model and it looks intentionally build that way.
osity
Postby osity » 14.12.18, 03:02
I think this thing is a Seagate FireCuda 500GB (ST500LX025) SSHD
ugggh
Postby digitalsupport » 14.12.18, 06:25
osity wrote:Source of the post I think this thing is a Seagate FireCuda 500GB (ST500LX025) SSHD
ugggh
If its a FireCuda you can id that on pcb very fast :)
osity
Postby osity » 14.12.18, 06:55
How?
Postby digitalsupport » 14.12.18, 15:57
osity wrote:Source of the post How?
On SSHD there is a NAND on pcb, typical a 8 GB TC58TEG6
osity
Postby osity » 15.12.18, 13:47
It doesn’t seem to have a nand chip on it. It’s the only one that I could find that was 500 gig that had the same chassis. I tried a couple 1 TB that looked to be the same, but they did not work.
Postby digitalsupport » 15.12.18, 18:31
Your pcb looks like a 100781943 88i1160 from a ST1000LM035 or ST2000LM007
I have also registered 100809471 with 88i1164 on the same 2 drives ST1000LM035 or ST2000LM007
Just go and check ROM info to confirm family ID
osity
Postby osity » 16.12.18, 01:30
Good idea :umnik:
Nick_TS
Postby Nick_TS » 26.12.18, 10:34
It looks like hybrid Rosewood or maybe Makara family.
Users browsing this forum: gautam.dotcom and 12 guests
