Seagate Barracuda LP ST31000520AS - BSY
lasek
Postby lasek » 11.07.18, 08:39
Hello Could you help me with this drive. Disk spin normally. Information about drive like model, serial or capacity are blank. I read some modules like 35, 93. Is translator has module 28, becuase I can't read this module?
Code: Select all
COM transfer baud rate set to 115200
Rd Sys File: vol = 3, FID = 028, Copy = 000...
Receiving file  FILE_3_028_0, length = 600064
Terminal: modem transfer unexpected code 0xD!
What I should do next?
On terminal I have:
Code: Select all
F3 T>
Hepburn VTPI/RAP16,128K dfcts,5K srvo,Yeti3,5900rpm DT
Product FamilyId: 40, MemberId: 03
HDA SN: 9VX07CL3, RPM: 5893, Wedges: 160, Heads: 4, Lbas: 748E3C90, PreampType: 58 21
PCBA SN: 0000C0199Y2Q, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 91, BufferBytes: 2000000
Package Version: HE0D7B.CCD3.DK0E2H., Package P/N: 100588875, Package Builder ID: AT,
Package Build Date: 08/20/2009, Package Build Time: 16:31:08, Package CFW Version: HE0D.CCD3.00198216.AT00,
Package SFW1 Version: B74C, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 08201631, CustomerRel: CC32, Changelist: 00198216, ProdType: HE0D.CCD3, Date: 08/20/2009, Time: 163108, UserId: 00236537
Servo FW Rev: B74C
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A2 06 03 03
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 compiled off
ASCII Diag mode
F3 T>
F3 T>V4
Reassigned Sectors List
Original     New    log log   log     phy     phy
    LBA      PBA    cyl  hd  sctr zn  cyl hd  sctr     SFI
         Alt   Pending  Total    Alted  Total
       Entries Entries Entries    Alts   Alts
Head 0              0
Head 1              0
Head 2              0
Head 3              0
Total        0      0       0        0      0
Total Alt Removals:    0
Checksum = 0000
F3 T>V40
Nonresident GList      0 entries returned
Total entries available: 0
    PBA    Len  Flags  Phy Cyl Hd  PhySctr    SFI
F3 T>
F3 T>
Rst 0x20M
ASCII Diag mode
F3 T>
F3 T>
F3 T>
Rst 0x20M
F3 T>
File Descriptor FD368093
File Size 00001200
Byte Offset 00000000
Bytes to write 00001200
F3 T>
F3 T>
Rst 0x20M
DiagError 0000000E
F3 T> F3 T>
Rst 0x20M
ASCII Diag mode
F3 T>
lasek
Re: Seagate Barracuda LP ST31000520AS - BSY
Postby lasek » 11.07.18, 15:42
case resolved after translator regeneration and cleared smart.
Aminvafi
Postby Aminvafi » 03.01.19, 13:24
tanx
