Rosewood adaptive transfer and head matching
Posted: 08.06.18, 00:42
by DNC_Scotty
Hi everyone,
I've got a Rosewood family drive P/N: 1R8174-568 F/W:SBK2 ST2000LM007 that needs new heads. Ordered a donor but the heads are a different revision given the sticker. Is there a process to transfer the adaptives from the donor to the patient rom?
Thanks!
Re: Rosewood adaptive transfer and head matching
Posted: 12.06.18, 20:34
by Doomer
In my experience you don't need adaptives transfer on Rosewoods
Posted: 18.06.18, 00:45
by DNC_Scotty
That ended up being true. The donor I was using ended up being defective. The second donor worked like a charm!
Posted: 19.06.18, 18:58
by Amarbir[CDR-Labs]
i always use brand new drives for donors in rosewoods
Posted: 25.06.18, 21:00
by Nick_TS
Doomer wrote:Source of the post In my experience you don't need adaptives transfer on Rosewoods
Indeed!!!
Posted: 22.07.18, 21:29
by Spark
I use brand new donor drive HSA too, the problem is after a while it start to skip sector (yellow) then if I change with another HSA I'm able to go ahead with image.
Result are that more drive are require to complete an image.
Someone got some suggestion
Posted: 23.07.18, 01:57
by LarrySabo
Are the failing heads contaminated after the short use? Perhaps just clean them and re-try.
Posted: 23.07.18, 02:59
by DNC_Scotty
How do the heads operate once place back into the donor hd?
