Rosewood-ST1500LM012-FW: SBK2-Get RDY but ABRT Error
jojo2012
Postby jojo2012 » 20.04.18, 09:59
Hi Guys,
I have to handle this patient. It spin up with no clicking or other noise, and get DRDY DSC, but when I launch the utility I get the error in attached.
I have not applied the patch yet, because I’d like your opinion about the error I get in terminal.
To me that “RESP = 0005” makes me think a problem with the heads.
Thanks so much for any advice or hint
Jojo
Re: Rosewood-ST1500LM012-FW: SBK2-Get RDY but ABRT Error
Postby AJ2008 » 20.04.18, 13:34
DWF - this suggests some mediacache issues. You need to unlock via ROM patching, and you can work over terminal and make repairs here also - note, the device will not work over ATA at all until you resolve this issue, so you will not reach good ID, or be able to work with modules table etc - use system files over terminal to gain access and repair - make sure important system files are backed up first.
jojo2012
Postby jojo2012 » 20.04.18, 14:32
AJ2008 wrote:Source of the post DWF - this suggests some mediacache issues. You need to unlock via ROM patching, and you can work over terminal and make repairs here also - note, the device will not work over ATA at all until you resolve this issue, so you will not reach good ID, or be able to work with modules table etc - use system files over terminal to gain access and repair - make sure important system files are backed up first.
Right AJ2008, meanwhile I'll try to unlock it, then I'll work with the system files as you said.
I will let you know...thanks
