SavedModePages: invalid signature!
Posted: 12.04.18, 16:15
Hi all,
I have here a Seagate ST31000528AS, FW44.
At arrived, the PCB was burned.
I have canged the ROM to another PCB. Same nocking Sound.
Now i read the ROM by terminal and write it to a same PCB from same type hdd with FW CC36.
The Patient hdd after start first nocking, but Startup an came ready, with capacity (0) MB...
LOG:
HDD family detecting...
Family ID: 3F
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST31000528AS
Tech Key...
Requesting FW Pkg ver ........ PH0G7B.CCD4.CT0L2H.
Detecting SA Phys Sct Size...
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 4
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
ID Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List)
4 12 Servo Adaptive Parameter File (SAP)
6 66 Read Adaptive Parameters File (RAP)
8 4800
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 1172 R/W Operating Parameters (translator, etc)
33 4576
35 26 SMART Data
3A 4
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6037200 33792 Read Adaptive Parameters File (RAP)
1 6037000 512 Controller Adaptive Parameters File (CAP)
4 4002C00 4096 Servo Adaptive Parameter File (SAP)
602BE00 4096
total 8192
A 60B4880 2048 Seek Profile
13 60C0A4C 864 Dependent Zone Table for User Area
14 60C0DAC 96 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60BE850 8700 Dependent Zone Group Tables for User Area
1C 60BE710 320 Dependent Zone Group Tables for System Area
1D 6037220 352 VBAR Configuration File
1E 60374B0 2416 Zone Format Parameters File
RAM:
ID MemOffs Len
2 6037380 304 Zone Table
602BE00 4096
total 8192
6 278044 40996 Servo Flaw Table
16 6037200 32 Drive Configuration Table
17 6039240 1216 Temperature Control Configuration
1F 618467C 1224 RW working user preamp table
20 6184B44 72 RW working system preamp table
Collecting DT Infos completed
System Files I/O method detection... ATA(direct)
Reading autotuning buffer............... Ok
Buff Root FAT searching in RAM......... Ok
Searching module table in RAM... ....... Ok
Searching DT table(RAM, WR) in RAM...... Ok
Searching DT table(RAM, RD) in RAM...... Ok
Searching volume 0 file table in RAM.... Ok
Searching volume 3 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
The solution for (0)MB Problem not work.
Log:
Test : Solution for the "Translation violation (0 GB)" problem
HDD capacity restrict. check (SetMax)...
HDD capacity restrict. check (SetMax)... : Error
SMART erase
HDD reply :
Clear SMART is completed.
SMART erase............................. : Error
Solution for the "Translation violation (0 GB)" problem.... : Error
In HD-ID (ROM) the Capaticy is correct, but in HD-ID(Rom) ist 0.
When i try to correct: failed.
Here is the LOG:
Test : Edit HDD ID (terminal)
HDD ID data source...................... : Terminal
Vol..................................... : 3
FID..................................... : 147
Copy.................................... : 0
HDD ID data destination................. : Terminal
Rd Sys File: vol = 3, FID = 093, Copy = 000...
Receiving file FILE_3_093_0, length = 4608
Writing Saved Mode Pages...
Wr Sys File: vol = 3, FID = 093...
XYMODEM send: waiting for receiver...
Blocks count: b1K = 4, b128 = 4
Verification............................ : Ok
HDD Identification reading ............. : HDD Redynes timeout (60000)
What can i do to solve this Problem?
Thnaks for helpful answer.
LOG:
Family ID: 3F
Tech Key...
Media Cache
ID Len
8 4800
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
3A 4
ROM:
ID MemOffs Len
602BE00 4096
total 8192
RAM:
ID MemOffs Len
602BE00 4096
total 8192
Log:
SMART erase
HDD reply :
Here is the LOG:
