Looking for FW DEMD from a seagate
Posted: 15.01.18, 16:31
by osity
500GB
LAPTOP Thin SSHD
Model: ST500LM000
Part number: 1EJ162-040
Can anyone help?
Re: Looking for FW DEMD from a seagate
Posted: 16.01.18, 13:48
by lcoughey
Posted: 17.01.18, 21:55
by osity
thanks!
I think I'm dealing with a corrupt firmware.
When I try to import my source adaptives into this provided ROM Ii get "Servo symbol tables are different!" error.
Posted: 18.01.18, 06:45
by digitalsupport
What errors are you getting at terminal?
Posted: 18.01.18, 17:52
by osity
No errors that I can see. Drive does not spin. I have swapped PCB with same results.
Here is my output:
Boot 0x40M
Trans.
(P) SATA Reset
RAW OFF
SOC PSM Mode = 0001 Atomic
SOC PSM Command = 0000 Flash Read
SOC PSM Status = 0011 Invalid PSM Parm
Clump Parametrics:
Clump = FE55
DataType = 0000
ModeFlag = 03
EraseCount = BFFAFFFF
EraseFailCount = 07
ProgramFailCount = 07
WeakReadCount = 1F
UncorrectableECCError = 03
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0000 FE55 FEAA 0004 8000 2F64 0000 C000 0011 C207 BC63
0200 FE55 FEAA 0004 8000 2F64 0000 C000 0011 C207 BC63
0101 0074 0000 0008 8000 2F5A 0000 C000 0080 C207 BC63
0000 00FF 09C0 0009 8000 2010 0000 C000 0080 C207 BC63
0F00 011B 0000 0008 8000 2F5A 0000 C000 0080 C207 BC63
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0400
LBAsPerCluster = 0x0020
LBAsPerClumpMLC = 0x4000
LBAsPerClumpSLC = 0x2000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x2000
UserSLCMaxSizeInClumps = 0x0180
NumberOfPotentiallyWrittenClusters = 0x0002
DefectListRevisionKey 0x0002
SLC Clumps 0x01A7
ActiveClumpInfo
Active Journal Clump 013F Offset 1700
Active Anchor Clump 0004 Offset 0460
DType 0000 Read Cache Clump 01F4 Offset 0000
DType 0001 Read Boot Clump 030D Offset 0000
DType 0008 Dirty Write Cache Clump 0190 Offset 0000
DType 0009 Dirty Boot Clump 0110 Offset 0000
DType 0011 Clean Write Cache Clump 001C Offset 0000
DType 0012 Clean Boot Clump 017C Offset 0000
DType 001A SIM Clump 0074 Offset 0020
DType 001B DRIVEFW Clump 019F Offset 0000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount Status Clump ClumpSentinel FunctionOrigin
ALFRecorder:
TableAdjustForMoveClump
MakeAnErasedClumpAvailable
EraseCondemnedClump
EraseCondemnedClump
EraseCondemnedClump
TableAdjustForMoveClumpToCondemn
ReconstructNodesInActiveClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
TableAdjustForMetaData
ReplaceNodePhysical
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
EraseTableSystemClump
WriteALFTables
SaveNewAnchorToFlash
AdvanceActiveAnchorPointer
WriteAnchorEntry
WriteAnchorEntry
WriteJournalLog
AdvanceActiveJournalPointer
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
WriteDataToFlash
JournalEntryForReplaceNode
AddEntryToJournal
ReplaceNodePhysical
IssueALFRequest
ReadDataFromFlash
Posted: 18.01.18, 18:33
by lcoughey
Want me to take a quick peak remotely?
Posted: 18.01.18, 19:35
by osity
you can.... i believe the ROM is incompatible....
Posted: 24.01.18, 19:15
by digitalsupport
Is the problem solved?
Posted: 26.01.18, 22:23
by osity
The problem is solved. Drive eventually just came ready as advised by lcoughey and all data was copied.
Posted: 30.11.25, 17:21
by divogame
lcoughey, Hello, can you help me with this case, i am also having the same case. thanks
