SSHD ST500LM000 Drive Busy FW: DEMD
Posted: 30.12.17, 20:57
Can't access to T, Tried this patch, still can't access T, http://blog.acelab.eu.com/pc-3000-f ... -work.html
Following message appeared, Drive Spins normally
Code: Select all
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
SOC PSM Mode = 0001 Atomic
SOC PSM Command = 0000 Flash Read
SOC PSM Status = 0011 Invalid PSM Parm
Clump Parametrics:
Clump = FE55
DataType = 0000
ModeFlag = 03
EraseCount = FFFFFFFF
EraseFailCount = 07
ProgramFailCount = 07
WeakReadCount = 1F
UncorrectableECCError = 07
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0000 FE55 FEAA 0008 8000 2F5A 0000 C000 0011 C207 AE73
0F00 FE55 FEAA 0008 8000 2F5A 0000 C000 0011 C207 AE73
0E01 0058 0000 0008 8000 394B 0000 C000 0080 C207 AE73
0D00 0181 0000 0008 8000 394B 0000 C000 0080 C207 AE73
0C01 013B 16E0 0020 0000 0000 0000 C000 0080 C207 AE73
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0400
LBAsPerCluster = 0x0020
LBAsPerClumpMLC = 0x4000
LBAsPerClumpSLC = 0x2000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x2000
UserSLCMaxSizeInClumps = 0x0180
NumberOfPotentiallyWrittenClusters = 0x0002
DefectListRevisionKey 0x0002
SLC Clumps 0x01A7
ActiveClumpInfo
Active Journal Clump 013B Offset 1700
Active Anchor Clump 0003 Offset 1D60
DType 0000 Read Cache Clump 03C9 Offset 0000
DType 0001 Read Boot Clump 036E Offset 0000
DType 0008 Dirty Write Cache Clump 0057 Offset 0000
DType 0009 Dirty Boot Clump 00DD Offset 0000
DType 0011 Clean Write Cache Clump 0052 Offset 0000
DType 0012 Clean Boot Clump 00E2 Offset 0000
DType 001A SIM Clump 0058 Offset 0020
DType 001B DRIVEFW Clump 0074 Offset 0000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount Status Clump ClumpSentinel FunctionOrigin
ALFRecorder:
ReadAnchorEntry
ReadAnchorEntry
ReadAnchorEntry
ReadAnchorEntry
ReadAnchorEntry
FindActiveAnchorClump
FindActiveAnchorOffset
RetrieveAnchor
ReadAnchorEntry
ReverseActiveAnchorPointer
ReadAnchorEntry
ReadALFTables
UseJournalToFinishALFTablesRestore
ReadJournalLog
ReadJournalLog
SaveALFTablesToFlash
RebuildALFTablesUsingMetaData
TableAdjustForMoveClump
TableAdjustForMoveClumpToCondemn
GetNewActiveClump
GetNewActiveClump
ReconstructNodesInActiveClump
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
TableAdjustForMetaData
ReplaceNodePhysical
GetNewActiveClump
GetNewActiveClump
EraseTableSystemClump
WriteALFTables
SaveNewAnchorToFlash
AdvanceActiveAnchorPointer
WriteAnchorEntry
WriteAnchorEntry
WriteJournalLog
AdvanceActiveJournalPointer
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
WriteDataToFlash
JournalEntryForReplaceNode
AddEntryToJournal
ReplaceNodePhysical
IssueALFRequest
ReadDataFromFlash
ERROR: Flash LED 9C1D - ReplaceNode Error replacing node - Invalid Clump
Target Start LBA 0000000080002F5A
Target Length 00000008
Clump FE55
Clump Parametrics:
Clump = 0400
DataType = 0000
ModeFlag = 00
EraseCount = 00000000
EraseFailCount = 00
ProgramFailCount = 00
WeakReadCount = 00
UncorrectableECCError = 00
0009 0400 4000 0008 0020 0002 0002 C000 0080 C207 AE73
0009 FE55 FEAA 0008 8000 2F5A 0000 C000 0080 C207 AE73
Flash Statistics:
Combo Mode
SLC Clumps 0x01A7
ActiveClumpInfo
ALFRecorder:
RetrieveAnchor
ReadAnchorEntry
ReadAnchorEntry
ReadALFTables
ReadJournalLog
ReadJournalLog
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
GetNewActiveClump
ReplaceNodePhysical
GetNewActiveClump
GetNewActiveClump
WriteALFTables
WriteAnchorEntry
WriteAnchorEntry
WriteJournalLog
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
WriteDataToFlash
AddEntryToJournal
ReplaceNodePhysical
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
IssueALFRequest
IssueALFRequest
IssueALFRequest
ReplaceNodePhysical
