ST1000LM035 - Head Map info in ROM Topic is solved
Posted: 06.12.17, 00:27
HDD ST1000LM035
Headstuck... I have after headstuck possibility to image about 9GB DATA... Then...:
Boot 0x80M
Low Current Spin
FAIL Servo Op=0100 Resp=0003
0100 0001 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1140 0085 0820 0CC0 0008 0000 0000 0000 0D2A 0000 0000 0000 0000 0000 0000 0DAC 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 Loop=007F
Motor startedHeads loaded
RECOV Servo Op=00DF Resp=0005
FAIL Servo Op=02DF Resp=0003
02DF 0000 0002 0000 7FFF 7FFF 0000 0003 0000 0000 8000 0000 FFFF 0000 0000 0000 0000 0000 0000 0000 0000 61B0 6666 A000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0004 0001 0004 5E2B 0000 D86B 00A5 FFC1 0000 0001 0EAB 0000 0000 0000 12D2 0DAC 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 041A Loop=0092
I have few donors
surface of plater is clean (Check in microscope)
i change heads... Unlock ROM
and the same log:
Boot 0x80M
Low Current Spin
and i cant import heads adaptives from ROM donor to rom Patient
Any ideas???
HDD ST1000LM035
Boot 0x80M
Low Current Spin
I have few donors
and the same log:
Boot 0x80M
Low Current Spin
Any ideas???
