ST4000DM000
Posted: 29.11.17, 23:53
by unspoken
Hello Folks, I can not do anything for solve cause terminal says "Diagnostic Port Locked"
I'm wondering latest version can solve this model.
Re: ST4000DM000
Posted: 01.12.17, 03:35
Can You Read Rom And Then Click On icon were you can find drive family code and let us know .Might be Go To Terminal And Issue Command CTRL + l To Get Some Info Of Drive .We Might Find Drive Family Are You using Latest Version of Tool .
Re: ST4000DM000
Posted: 01.12.17, 12:40
by unspoken
Hello Amarbir, thanks for reply.
I didn't read rom via bootcode. I thought this is the reason cause Rom size 1 MB.
I tried CTRL+L and other all basic commands but dont work."Diagnostic Port Locked" . So i didn't learn drive family not yet.
CTRL+a gives me that
F3 T>
Prod Desc: V9 SATA SBP 250Z 4KSys 5XXE, 1MB flash
Package Version: V9A2010B0.CCD7.VAB00G.
Serial #: WDHxxxxx
Changelist: 01098643
Model #: ST4000DM000-2AE166
Servo FW Rev: B025
Heads: 6
PCBA SN: 0000E711HRV0
Default factory config: SD&D
Active config: SD&D
Re: ST4000DM000
Posted: 01.12.17, 12:57
Hi ,
Go To Tools , Utility Extension , Work With Flash Rom Image File .The Try To Read The ROM using Read Via Boot Mode .Then In Minimum Image Size Remove The 1 Make is 0x000000000 "This Will Make The Common Utility Detect Proper ROM Size .I have no idea which guy has given them this stupid idea rom size should be fixed to 1024KB .Seriously TS Guys This is one hell of a annoying thing in tool now solve it in next update make default to 0x00000000 .Then Read Rom And Post What Family Code You Get In Icon Next To ID Icon .I Need To Find Family Code
Re: ST4000DM000
Posted: 04.12.17, 08:33
by digitalsupport
ST4000DM000 is a Lombard (70)
Re: ST4000DM000
Posted: 04.12.17, 11:34
by unspoken
I've already tried it. but it did not succeed. there is another one in the same model and it's Lombard. Have any solution if you assume that it is from the same family. (Diagnostic Port Locked)
Thanks Guys.
Re: ST4000DM000
Posted: 05.12.17, 07:11
by digitalsupport
What happens if you use the Unlock "Lombard, Megalodon" command ?
Re: ST4000DM000
Posted: 05.12.17, 08:15
by unspoken
My fault. I asked because my PC3K is new version. I got the answer I wanted now. so there is a solution with new version.
