ST4000LM016-1N2170 Low Current Spin
Posted: 02.11.17, 08:40
So I was able to unlock the SA and save all the resources. 10 heads. All but one are acting normal. I was able to save all data from the 9 heads working normally. When I attempt to save data from the weak head, it will read then fail and lose readiness. When I restart the drive the terminal says this:
Here's where it get's kind of weird. If I leave it alone for a bit, it'll work again, become ready and allow data access again. Resistance between motor coils seems to be 2.4 Ohm (but I'm not completely sure I measured correctly) I don't have another drive of the same family to compare to.
Am I just looking at a bad head here or is it something else?
Boot 0x80M
Low Current Spin
FAIL Servo Op=0100 Resp=0007
0100 0001 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1640 0087 8252 F180 0008 0000 0000 0000 0B88 0000 0000 0000 0000 0000 0000 0E2E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
