8C, Rosewood_8C Sys file writing Problem
Posted: 07.09.17, 06:01
by bikram
Hi All,
I have ST2000LM007-1R8174 Mobile HDD when start the Utility DRD DWF DSC all Signal on. below is problems.
1. After unlocking the Terminal port how can i Backup the all Modules and Sys File because F/w Area Not Access DRD DWF DSC all Signal on.
2. Reading System file with Terminal but after translator system file not writing.
3. It is possible we can reading modules with terminals before translator if yes Please tell me how can.(because F/w Area Not Access DRD DWF DSC Signal on.)
I have 4 hard disk when start the Utility DRD DWF DSC all Light on. we can unlock the Terminal and Translate the hard disk problem is solve but all hard disk sector reading problem i try to recover translator but sector reading not success fully done.
Any Solution in this problem help me Ace-lab please consider this problems.
Bikram singh
Re: 8C, Rosewood_8C Sys file writing Problem
Posted: 18.09.17, 12:37
by Maxim_TS
bikram, please read this article first: http://blog.acelab.eu.com/pc-3000-f ... rives.html
The writing works thru the ATA, not thru the terminal in such drives.
Check if all system files are good, make the backup of translator and Non-Resident G-List BEFORE any actions.
If you didn't make the backup - it could be almost impossible to get the data.
Posted: 18.09.17, 13:08
by AYNIADAM
I'm having the same problem. There is no problem removing the lock
Access to the entire service area is available. But any writing operation can not be done on the service area. For example MCMT error resolution
http://forum.acelaboratory.com/viewtopic.php?f=154&t=9395
Posted: 20.09.17, 18:37
by Nick_TS
AYNIADAM wrote:Source of the post But any writing operation can not be done on the service area.
Try to write the system file via ATA indirect. And please pay attention that MediaCache is not 346 system file on Rosewood family.
