Page 1 of 2
Rosewood ST1000LM035-Sysfile Write Eror
Posted: 04.09.17, 12:33
by AYNIADAM
Hi.
I have ST1000LM035 Seagate disc.
We are getting an MCMT error on the disk.
We are following this procedure first because this serade terminal is locked. : http://blog.acelaboratory.com/pc-3000-for-hdd-seagate-f3-unlocking-the-rosewood-drives.html
After the terminal is turned on, we apply the MCMT problem resolution procedure: http://blog.acelaboratory.com/pc-3000-for-hdd-seagate-f3-mcmtfilehandler-exception-failed-mcmt-read-request-error-and-how-to-fix-it.html
But the Sysfile write operation does not work. There is no problem in reading, it is getting error in writing.
Is there a solution?
Re: Rosewood ST1000LM035-Sysfile Write Eror
Posted: 20.09.17, 18:49
by Nick_TS
Dear AYNIADAM,
Try to write the system file via ATA indirect.
Posted: 28.09.17, 10:19
by AYNIADAM
"MCMT table is corrupted" I am rewriting the 346 file to resolve this error, but it is not resolved.
Code: Select all
Boot 0x80M
Tech Unlock Handshake: 0xB5107352
Reply:
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
 PASS
(DOS Table) Worst Count: 00000C40 At SU: 000CC42A NT: 00000000 OT: 00000003
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
Posted: 28.09.17, 12:12
by AYNIADAM
Problem is solved. There was a different solution for MCMT failure.
Posted: 05.10.17, 03:00
by 300ddr
@AYNIADAM Can you share the solution you used please?
Thank you,
Brian
Posted: 05.10.17, 10:12
by Masterclass
AYNIADAM wrote:Source of the post Problem is solved.
I do hope you found solution better that silly initing MC Table
Posted: 11.02.18, 14:30
by AYNIADAM
friends did not write here because in some cases the solution does not work. are largely solved by two separate methods.
Since this method is dangerous, it may be wrong to share it explicitly. I write with private message to the entrants.
Posted: 11.02.18, 19:52
by DNC_Scotty
I would like to know....Thanks
Posted: 13.02.18, 23:36
by Ohtic
I would also like to know. Thank you :)
Posted: 27.02.18, 19:40
by Nick_TS
AYNIADAM wrote:Source of the post "MCMT table is corrupted" I am rewriting the 346 file to resolve this error, but it is not resolved.
I would not advise to overwrite MediaCache system file on Rosewood drives.
MC is 348 system file on Rosewood.
Posted: 13.03.18, 15:20
by Wanderson
Posted: 13.03.18, 15:38
Read by system file, execute any repairs/fixes, restore any modules that need restoring via modules table after loading modules tables immediately after handshake.
Posted: 20.03.18, 15:49
by Nick_TS
Unfortunately, MediaCache FileID is not shown via Ctrl+X combination.
To fix the system file needs to read using sector-by-sector mode and try to fix the file manually.
Posted: 27.03.18, 09:53
by suardim
AYNIADAM,
I would also like to know, if you can share.
Thank you
Posted: 18.08.18, 01:17
by Alberto
i would like to know the methods
