What screwdriver to opening ST1000LM035 ?
Posted: 19.07.17, 16:56
by recovery
We search how to open the Seagate "mobile HDDs". The screw behind the label is not a Torx. See the following pictures:
Do you know what screwdriver we need?
Re: What screwdriver to opening ST1000LM035 ?
Posted: 19.07.17, 20:01
by Blizzard
This is a pentalobe screw. I have seen the HSA and ramp screw on Seagate mobile HDDs are pentalobe but the metal cover screws were still torx.
Posted: 20.07.17, 18:13
Hello ,
its a pentalobe 1.5mm not pentalobe 1.2mm ,Little Rare To Find ,German Brands are best
Edit : Its Not 1.5mm and also Not 1.2mm .Though Only 1.2mm Screwdriver in pentalobe will fit into this but i think Seagate has a ODD Size ,It Should be 1.3mm .1.2 mm is a bit loose and 1.5mm does not fit ,What the heck i would say,just like in platter they use T7 in many HDDs odd size
Posted: 25.07.17, 10:59
by recovery
Thank you all, for your help. We will try to find a proper screwdriver.
Posted: 10.08.17, 22:29
by goooz
Pentalobe 1.2 works well
- k-ST1000LM035.jpg (9.97 KiB) Viewed 13113 times
Posted: 19.09.19, 19:14
by osity
goooz
What does it mean in your picture where it says' "not for cover" (magnet) ?
Posted: 19.09.19, 22:40
by RevocoTT
It means it's not part of the cover, it holds down the magnet for the heads.
You don't need to remove it, unless your doing a transplant.
Hope this helps.
Posted: 20.09.19, 18:06
by osity
ah, I thought you were implying the screw somehow had magnetic properties.
Posted: 13.11.20, 21:32
by osity
They also use this screw on the cover on the Seagate 5TB ST5000LM000, although it is a bit bigger.
Maybe it's a 1.5mm for the ST5000LM000? Anyone know?
Posted: 14.11.20, 17:41
by Doomer
osity wrote:Source of the post They also use this screw on the cover on the Seagate 5TB ST5000LM000, although it is a bit bigger.
You can buy
Wiha 26794 Precision Pentalobe Screwdriver Set (PL1-PL6)
You can use 3 screwdrivers from this set, for Rosewood, M11 and WD BigBear
