seagate ST2000LM007 -SBK2 diagonstic port locked
Posted: 25.04.17, 09:46
i have a model seagate ST2000LM007 mobile hdd. its shows id and correct size. but not able to read any sector. i can access terminal. when i press cntrl+L its shows " diagonstic port locked". please see startup log below
Boot 0x80M
Rst 0x80MSrv DETCR init 0x0000
EDAC Value = 0000F018E59FF018
(P) SATA Reset
RAW OFF
PASS
EDAC Value = 00000000FFFFF844
(DOS Table) Worst Count: 0000100C At SU: 00004C33 NT: 00000002 OT: 00000007
MCMT table is corrupted
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
when press cntrl+L
F3 T> "diagonstic port locked"
please check below log while reading ROM
Model by ID............................. : ST2000LM007-1R8174
Tech Key...
Requesting FW Pkg ver ........ RT0898.SDM2.CC4618.SBK2
Detecting Phys Sct Size...
Error obtaining Phys Sect Size!
GetModePage 0x3 err! Tech state 0x72, 0x07200200
Terminal : error detecting HDD terminal baud rate
Test : Read ROM
Reading ROM to profile folder
Folder: E:\PC3000-E\!Profiles\SgF3\F3 Arch (common)\ST2000LM007-1R8174-SBK2-WCC2NJSB\Data\ROM\
File : ROM.bin
Error : DT ID 15 is not found!
Test : Read ROM
File : ROM.bin
Switching HDD power supply ON
Error : Terminal : reply timeout error
WARNING!
In Boot Code mode HDD have shortened commands set!
For full-mode work via utility you have to switch HDD power supply OFF/ON!
any help. i get many of this drives
Boot 0x80M
(P) SATA Reset
RAW OFF
PASS
Intel 6G->3G
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
when press cntrl+L
Tech Key...
Test : Read ROM
File : ROM.bin
Test : Read ROM
File : ROM.bin
WARNING!
