i have a model seagate ST2000LM007 mobile hdd. its shows id and correct size. but not able to read any sector. i can access terminal. when i press cntrl+L its shows " diagonstic port locked". please see startup log below
Boot 0x80M
Rst 0x80MSrv DETCR init 0x0000
EDAC Value = 0000F018E59FF018
(P) SATA Reset
RAW OFF
PASS
EDAC Value = 00000000FFFFF844
(DOS Table) Worst Count: 0000100C At SU: 00004C33 NT: 00000002 OT: 00000007
MCMT table is corrupted
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
when press cntrl+L
F3 T> "diagonstic port locked"
please check below log while reading ROM
Selected family......................... : 00, F3 Arch (common)
Model by ID............................. : ST2000LM007-1R8174
Tech Key...
Requesting FW Pkg ver ........ RT0898.SDM2.CC4618.SBK2
Detecting Phys Sct Size...
Error obtaining Phys Sect Size!
GetModePage 0x3 err! Tech state 0x72, 0x07200200
Terminal : error detecting HDD terminal baud rate
Test : Read ROM
Reading ROM to profile folder
Folder: E:\PC3000-E\!Profiles\SgF3\F3 Arch (common)\ST2000LM007-1R8174-SBK2-WCC2NJSB\Data\ROM\
File : ROM.bin
Error : DT ID 15 is not found!
Test : Read ROM
File : ROM.bin
Switching HDD power supply OFF
Switching HDD power supply ON
Error : Terminal : reply timeout error
WARNING!
In Boot Code mode HDD have shortened commands set!
For full-mode work via utility you have to switch HDD power supply OFF/ON!
any help. i get many of this drives
seagate ST2000LM007 -SBK2 diagonstic port locked
Re: seagate ST2000LM007 -SBK2 diagonstic port locked
Sir ,
Model Not Supported In PC3K Yet
HDD ID Display But LBA: 0
Solution :
Solution :
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Vijayan MBA
call 7092114411/22
I would ignore EDAC values but instead focus on 0LBA which is symptoms of a translator issue. You can unlock these models on PC3000, but there is a risk of data loss when clearing translator and associated MC data, so ensure a full SA backup is made before any attempts to resolve the translator.
Well ,
This Can Be solved Now
Case Solved Ts team
Best regards,
Vijayan MBA
call 7092114411/22
Vijayan MBA
call 7092114411/22
