7200.12 ST31000524AS Cannot Access Terminal
Posted: 18.03.17, 22:18
by cnfcomps
Drive Details:
SEAGATE BARRACUDA 7200.12 ST31000524AS 1TB
P/N: 9YP154-516
Firmware: JC45
PCB: 100574451 REV B
The drive spins up and sounds like it is initialising correctly, but remains in a BSY state. It gives several LED error codes, but the first one that is shown is 'LED: 000000CC FAddr: 000075A5', so I was hoping to try the 'Solution for the "HDD Lock (LED: 000000CC)" Problem'. However, I cannot access the terminal prompt whichever way I try. I found the shorting points for the PCB in another post (viewtopic.php?f=154&t=8923&p=31175&hilit=100574451#p31175) and they appear to work, as the drive clicks at startup whilst the points are shorted. However, the 'DRD' and 'DSC' lights come on but the drive does not spin down, and no commands can be entered into the terminal.
Please help!
Thanks,
Matt.
Re: 7200.12 ST31000524AS Cannot Access Terminal
Posted: 22.03.17, 04:09
by Amarbir[CDR-Labs]
Matt ,
I am sure this one can be done ands right now its still a firmware issue
Posted: 27.03.17, 17:26
by Nick_TS
Hello Matt,
What is shown in Drive ID?
