ABORT! SenseCode from a drive that was reading well but now not all
Posted: 14.03.17, 19:54
I was originally able to read most sectors but eventually hit a large rough (timeout) patch with H2 and H3.
It seemed to stop reading completely shortly after clearing SMART and/or G list (T>i4,1,22). I did both.
Now, none of the heads read anything and I get this in terminal when I start the utility.
ABORT!
SenseCode = 03310000
ReadyStatusFlags = 0002A1A5
Any ideas what this error indicates?
Could the clear G list command be the cause of the heads no longer reading user area?
Currenty the drive comes ready with Full ID.
Tested heads with X and output is fine.
I am able to read system files fine.
All critical modules are good.
is there anything I can try?
ABORT!
