I was originally able to read most sectors but eventually hit a large rough (timeout) patch with H2 and H3.
It seemed to stop reading completely shortly after clearing SMART and/or G list (T>i4,1,22). I did both.
Now, none of the heads read anything and I get this in terminal when I start the utility.
ABORT!
SenseCode = 03310000
ReadyStatusFlags = 0002A1A5
Any ideas what this error indicates?
Could the clear G list command be the cause of the heads no longer reading user area?
Currenty the drive comes ready with Full ID.
Tested heads with X and output is fine.
I am able to read system files fine.
All critical modules are good.
is there anything I can try?
ABORT! SenseCode from a drive that was reading well but now not all
Re: ABORT! SenseCode from a drive that was reading well but now not all
Head 00 Resistance 01F5
Head 01 Resistance 01A6
Head 02 Resistance 01D5
Head 03 Resistance 01D2
Well,
The First Thing You All Do is Attach Smart Module And Clear It and Also Growing Defect Lists ,Mostly They Are Never a Issue
Amarbir,
What do you mean "attach smart module"? Are you suggesting I clear smart and G-list again?
osity wrote:Source of the post The First Thing You All Do is Attach Smart Module And Clear It and Also Growing Defect Lists ,Mostly They Are Never a Issue
Sorry ,
There was a Typo Error ,I Wanted To Say "The First Thing You All Do is Attack/Clear Smart Module And Clear It and Also Growing Defect Lists ,Mostly They Are Never a Issue "
