Is ST1000UM000 supported? Can't import adaptives into ROM.
Posted: 03.02.17, 23:56
Got this drive in completely dead, no terminal output. Same with PCB + ROM swap. But, donor ROM + PCB spins up (even gives LBA access to first 15 sectors). So, I think it has corrupt ROM.
Luckily, I can save the ROM with Boot Code. But, I get errors when trying to import its adaptives into a donor ROM. Turns out, I can't view the head map (logical or physical) either, but the ID works and is correct.
Is this model not supported?
