Initially problem was that 250 Gb ST3250312AS drive with HP64 FW doesn't have an access to sectors after LBA 67881706. When you run Recover translator it will fail exactly on first unreadible LBA.
Let' s check it with Work with SA -> Translator -> Convert LBA to CHS instrument:
As we see in the log at this cylinder there is a shift in 2 sectors. Let's check P-list entries in this cylinder:
As you see, there is only one entry. That's called a P-list duplication bug.
Solution is simple - delete duplicated defect from P-list and run Recover translator again
