St932032As partial access on LBA
Posted: 28.07.16, 11:33
by redlabs
Dear Frds ...
I have received 320 GB wyatt family F/w : 0002BSM1 , reading partially 0 - 300000000 LBA sector only total 298.09 GB (625 142 448) ..Please give me any solution for this case
Re: St932032As partial access on LBA
Posted: 31.07.16, 07:16
by redlabs
Any one knows please update frds
Posted: 01.08.16, 09:44
What was original symptoms when you received this case?
Posted: 01.08.16, 15:28
by redlabs
same reading problem friend ...
Posted: 01.08.16, 17:22
Can you post output from V40 here?
Posted: 02.08.16, 07:52
by redlabs
Rst 0x08M
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
F3 T>
Thank you
Posted: 02.08.16, 10:24
NRG is empty and since you have partial translator loaded I assume NRG entries were cleared during some translator rebuild.
Did you try to run Recovery Translator option?
Posted: 02.08.16, 11:20
by redlabs
YES I try to rebuild but same result finally ..
Posted: 02.08.16, 11:48
Did Translator Recovery option complete or did it give error about correcting manually?
Posted: 02.08.16, 11:52
by redlabs
If i run translator ,Lots of UNC error is coming and not completed ,I have stop that translator recovery
Thank you frds ,please give me your suggestion
Posted: 03.08.16, 07:21
by redlabs
hello frd
Please update ..
