Seagate SSHD Kahuna,5400, not spinning Topic is solved
Posted: 20.06.16, 02:22
I have a dead drive and need your technical advise to fix it for data recovery purpose :
Original drive:
Seagate thin SSHD 500GB
MDL:ST00LM000
F/W:DEMC
Problem: Dead, not spinning, Busy all the time
What I did: Mounted donor drive's pcb on patient, starts spinning without any noise and becomes ready but of course can not access the user data.
Donor drive with patient PCB mounted does not spin and busy all the time. I concluded that the PCB is dead, so after backing up of all donor drive's ROM and modules I disoldered and transferred the
patient ROM to the donor PCB. Then, mounted the donor PCB on patient drive...same problem as original patient PCB, does not spin and busy....
I removed patient ROM and mounted back the donor ROM to the donor PCB, works fine on donor drive!
My final conclusion is that the original ROM is dead and I have to recover data from this HDD without having original PCB and ROM data.
My question is that:
1- For THIN SSHD drive, in order to adapt the donor PCB, is it enough just to transfer the original ROM to donor PCB? or I have to take care of other maters too?
2- From the above explanation, if your opinion is that the original ROM is dead, then is there any solution to recover data from this HDD without having original ROM? I would like to have your kind advise in this regard.
Donor drive:
MDL:ST00LM000
F/W:DEMG
PC3000 express recognizes the drive as:
72, Kahuna, 5400
I appreciate any help or advise
Original drive:
MDL:ST00LM000
F/W:DEMC
Donor drive:
MDL:ST00LM000
F/W:DEMG
72, Kahuna, 5400
