ST3500418AS peculiar problem.
Posted: 09.04.16, 15:06
I have the mentioned HDD. The HDD spins down after 11 clicks. So i think its head problem.
On running utility, T> is avialable in terminal though the drive is not spinning.
On giving command /2,U it starts spinning with Diag 6008 error. The spinning does not stop but T> is not taking any command.
Changed the PCB after ROM transfer and changed the head also from an identical hard disk.
The problem remains the same. Any solution will be highly appreciated.
