Creating a loader from saved resources
Posted: 31.03.16, 19:18
I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
pclab wrote:Source of the post If you know the loader version, you can get it from another drive.
Amarbir[CDR-Labs] wrote:Source of the post Still Not Understood when you Folks apply Loader In F3 Family ,When and why Is My Answer .
msurgeon wrote:Source of the post I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
Dmitriy_TS wrote:Source of the post Hello msurgeon and Amarbir,Amarbir[CDR-Labs] wrote:Source of the post Still Not Understood when you Folks apply Loader In F3 Family ,When and why Is My Answer .
Loader is used when the drive comes to ready state but you can't send any terminal command due to damaged diagnostic overlay. A loader applies the diag ovellay in RAM via ATA command.
For detailed procedure you can read video:
https://www.youtube.com/watch?v=l6XZ_mIlZSYmsurgeon wrote:Source of the post I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
You have to save system file (100 - 105). If you have these system files then contact our TS department (ts.acelab.eu.com) we will create you loader from these files.
