Problem of PCB from SSHD disk...
Posted: 25.01.16, 15:12
Hi everyone,
My Seagate SSHD - model Laptop Thin ST500LM000, f/w: DEM7 is death (not spin up).
I made the basic work and checked the simple elements of PCB (transil, resistors 0, cleaned contact strips, even resoldered the motor controller) - unfortunately - the drive still the same "dead".
Access via terminal is not available. When power on - BSY. Anyway - the same PCB somehow works - i can download the BIOS by the terminal in PC3K.
After reprogramming (or resoldered) the BIOS (by PC3K) drive remains a dead (if donor PCB has a different firmware). With the identical donor PCB (the same firmvare version) and reprogramming the BIOS disk spin up but with parameters (sn, etc.) from donor. Like identical after hot swap. Of course, can't read SA and user area......
It seems to me - that because it is hard SSHD - start the drive is very fast (before it gets started motor). To make this possible, some are some startup information must be included in ROM and NAND of the disk.
I my opinion, theoretically are there way to recovery data.
First: repaired PCB.
It may be difficult because the same PCM can be effective. If they are physical or logical errors in NAND this possibility will not be successful. Only, when any others element is damaged (fe. transistor). Further risk when resoldered critical element (bios, NAND, ASIC) to other PCB - these components can be damaged....
Second: Disable feature of SSHD.
Perhaps we can block all that SSHD (any bypass) and switch to work as a normal HDD.
In my opinion this way is the best. Question: If we can disable the NAND - how to do it ?
Third:
Replace critical startup information from own patient NAND of PCB to donor NAND of PCB.
Similar question: If we can - how to do it ?
Can someone please help ?
I thank You in advance for your help.
igen
Third:
igen
